yeah you are probably right, thats why breaking it in hard gets the best seal. ill keep you updated as to how this works for mesnozepp147 said:yeah that article is really good. i'll be breaking my rebuilt gsr block in that way when i install it. thats impressive how much better the rings seal if you run it hard right out of the gate and use no synthetic at first. it makes sense and has been proven by many people.
in fact the reason my rings are shot after driving the motor for only 1,000 after the rebuilt could be because it was broken in *very* softly, no vtec for the first 300 miles. the rings rings set based on that and then when i started driving it hard, they didn't have the same compression.
good luck with the break in process and let me know how it goes, as i'll be doing this with a rebuilt motor.
stealthy said:oh, btw, i havent got to drive it yet...................i have to replace the rear driver side caliper. while it was sitting in my garage i had the ebrake on for about 2 months, and it locked up on me. it was so hard to remove, i had to pry it off with all i had lol, that car was NOT moving. i took it off and the seal was all cracked so im assuming that is the cause. im going to replace that today with a whole brand new caliper, and should be able to put my first 100 miles on it tonight and change the oil.
well, i wasnt thinking. not to mention i didnt think itd take this long (as it shouldnt). oh well, atleast i have a new caliper right? ha.EG-Owns you said:moron wtf were you thinking you need to jack it up on all 4 jackstands so the tires are off the ground so the breaks dont get stuck learned the hard way eh?? lol
stealthy said:lol.
might as well keep it warm since you arent working on it.EG-Owns you said:ya b***h you know im right EG owns you ahaha glad to hear it running now my car is now sitting under blankets in the grage lol
stealthy said:might as well keep it warm since you arent working on it.
EG got owned
Make sure the axles are seated properly. I had a slight jerky kinda vibration when I first did my swap, and one axle was about 6-8mm from being completely seated..stealthy said:i got the caliper fixed, so now the brakes work! lol. ive got the first 20 miles under my belt for the break in process, then came home and changed the oil. you could see a tiny bit of metal "flavor" to the oil, as expected. finally bled the clutch (again), coolant, and the brakes too. i def need to get used to no PS again. and for those who dont know, i removed the AC and cruise too.
so....
the goods....
- the car ran good. pulled really hard. harder than before, which suprised me with it being 9:1cr.
- vtec is really loud now, and noticable. idk why, i/h/e was not changed. lol
- idles good
- ITS DRIVABLE!!! LOL
the bads....
- the temperature guage is reading really weird. took awhile for it to get up to half way, and then all of a sudden dropped to nothing, and went back and forth in between. not sure why yet, however the fan DOES kick on. thats good.
Probably air moving around in the system, and pockets of air reaching the CTS. This will make the temp gauge move erratically.
- it was reading VERY VERY little oil on the dipstick during the break in. after changing the oil, it now reads where it should, weird.
Was it full, to start with? Or did your small leak lose that much oil?
- there is a small oil leak when it is running, noticable while its sitting. i cant find where it is coming from, so ill be looking more into that.
Where does it "look" like it's coming from? front? back? either side? Hope it isn't a rear main seal
- there is a slight "hop" when taking off in first gear at low rpms. idk if its the axles (same i took out) or the ball joints, or what. i need to figure that out too.
