for the temp. gauge being wierd- try checking the voltage on the wires going to the coolant temp sensor.
glad the break in process is going well. i can't wait to try it.
stealthy said:with the zex kit you dont really need to tune or anything. i ran it on my completely stock gsr with zex plugs and everything was fine.
my motor loved it. what kinda kit did you useEG-Owns you said:tisk tisk tisk your motor probably hates you lol i would be sure to get it tuned. lol i wouldnt want to hurt a newly built motor man if i were you if you dont have the money to get it tuned hold off on it for a bit becuase if somthing does go wrong your gonna be pissed like i was lol. sprayed on an untuned B16 and it went kabooooom!!!
no way. slowmotion? i would never go there. to get it tuned for boost im going to Evans in PA. i had a crome street tune on my lsvtec??ImportFan1 said:i thought you got one in Columbus?
oh. yeah, i had one but it was only temporary and lasted 4 weeksImportFan1 said:sorry. i meant a job in c-bus.
stealthy said:yep, still looking for a job.
im using a dry zex kit as well. i was just trying to calibrate the wot switch, and for some reason its not "learning". ive got the power, ground, and switch wired up just like before. to set the wot point, you are supposed to turn "on" the car (not start), flip the switch to on, and the light should go to red......but evertime i switch the switch on, the zex box clicks kinda like the solenoid or something....idk what the problem is. the first time i hooked it up everything was fine.
