U never know. It can cause irreperable damage.
Yea I know that's why I askedU never know. It can cause irreperable damage.
I have my b18b1 still sitting all wrapped in a box. Completely disassembled and LOTS AND LOTS of fresh OEM honda parts which include...My car burns alot of oil. I'm assuming that's the issue but that's why I'm saving for a swap so I can do away with the single cam. I have been thinking of buying a bare block and building it from the ground up so I can get some experience with building motors. I seen a few bseries blocks for sale. But I don't know the cost of starting a built from scratch. I'm assuming it isn't cheap.
I'd say no it's not. A spun bearing is usually just someone not putting oil in it. Replace the bearings and typically you're good but. Someone who didn't put oil in the car could've caused more damage then a bearing.Yea I might just look for a short block and start from there. Would buying a block with a spun bearing for cheap be a bad idea?
No I stick to the same gas stations. I just changed the cap&rotor so far so good. No cel. But if it comes back on ill change the wires. I have a warranty on them.Did you recently change gas stations? Should always use the same gas station...ignition coil? Check your timing.
Keep us updatedNo I stick to the same gas stations. I just changed the cap&rotor so far so good. No cel. But if it comes back on ill change the wires. I have a warranty on them.
Will doKeep us updated
Well right now I'm just changing things a know my car can use. But I do need to check my injectors but honestly I don't know how to other then unplugging them while the car is running to see if I notice a change in how the car is running.first thing you need to do is check if the misfire is from lack of fuel or spark
from there i can help you. i just did all of the test for both situations since my car was whooping my ass
bingo, if it doesnt effect it then you found the dead cylinder. checking for spark is easy too. you probably dont have an inline tester so the backyard method is to put it at a ground like a vc bolt. if you got spark then you dont have fuel.Well right now I'm just changing things a know my car can use. But I do need to check my injectors but honestly I don't know how to other then unplugging them while the car is running to see if I notice a change in how the car is running.
Buy it up!I'll have pics up later. The guy also has some integra rear disk he will seek me for 40 buck. He sold his EK and is tryna get rid of all his stuff.
