all good, I normally forget I even have it. just sits in one of my spare tool boxes lolI would of took you up on that offer had I known sooner.
I have no idea what the history behind the head is but I plan to get it resurfaced and throw in some dual valves spring and retainers.yup that's a hmotors stamp. They started doing those stamps in more places a few years ago. Whoever had that head must have beat the crap out of the motor lol
Why is laying them down bad? The cam caps on a b16 are numbered already from factory with arrows which should point towards the cam gear when installed.it's not good to lay cams and cranks on their side just so you know. and hopefully you labeled all the cam caps since they have a specific spot they gotta be in
causes slight warpage in then, it doesn't take much when your dealing with .0010 of an inch sometimes. just like valves need to be out in the same spot also.Why is laying them down bad? The cam caps on a b16 are numbered already from factory with arrows which should point towards the cam gear when installed.
well I mean if you do all the measurements yourself. if you have a machine shop they do it for 8 hours straight and have every tool possible ready to goThere's a lot of people, teams, and manufacturers you need to tell that to then.
I didIt's proper information, but it's also generalized information. The way his cams are, they are not going to be effected. A cam with no gear on it, laying on its lobes on a hard or dirty surface could make small changes in such a precisely designed piece.
Gotta apply that college education
to each their own. I'll just listen to the professionals. just like theirs an order in which your supposed to remove cam caps because t can warp it or even snap itHow heavy is that cam lol. Some extreme leverage going on haha, or some aluminum cams
