Post your turbo setup
majorahole
d16z6
pre-cat manifold modified by me
dsm t25
dsm 450's
Crome (basemap still!)
home made downpipe made by me
300zx sidemount intercooler, mounted in front
10psi
ABS CHARGE PIPE!!! (f**k ya)
audi BOV
never dyno'd, will this summer after i get an lc-1
total cost to me about $500 (turbo was free)
Steven.
Formally Green 91
my bros kit
Dezod motorsports
T3/T4
Tial 38mm waste gate
Tial BOV
E manage blue
Innovative Wideband
rated:
164whp & 142wtq on 5 PSI with an automatic transmission when tuned, witch we still have to do.
my bro has a manual BTW
update:
Upgraded to Dezod V3 manifold, new DP, and upgraded injectors to 570cc, he was running stock RSX Type S injectors(310cc)
now making 240whp/214wtq @12psi.
not bad for 100% stock engine, clutch,tires, and suspension
SiRcivic27
This will be my car towards the end of March
Greddy Turbo Kit
Greddy I/C kit
Greddy Turbo timer
Greddy Type S BOV
Exedy Stage 2 clutch
ACT streetlite flywheel
AEM Fuel Rail
GM Boost controller solenoid
AEM 3.5 Bar MAP sensor
AEM air intake temp sensor
AEM EMS w/built in wide-band
Full Dyno tune
I'll edit this post with pics and numbers once the work is done.
littlewhitecivi
Precision SC–6169E Turbocharger (Compressor: 61mm < 82mm, 0.60 A/R) (Turbine: 74mm > 61.5mm, 0.63 A/R)
DRAG Cast Iron Short Length Turbo Manifold (Ported)
DRAG Turbine Pipe (Flange: 60mm < 73mm)
ANSA Automotive Silverline Resonator (458mm x 73mm)
Dynomax Super Turbo Muffler (407mm x 76mm)
JE/SRP Pistons (9.0:1 Compression Ratio: Ceramic Barrier Coated Dishes & Teflon Film Lubricated Skirts)
Crower 4340 Steel Billet Connecting Rods
Cometic HP Head Gasket (0.054”)
ARP Heavy Duty Head Studs
NuFormz Block Guard
Unorthodox Racing Ultra SS Pulley Set
TiAL Sport F38 Wastegate
Hallman ES Manual Boost Controller
HKS Racing Blowoff Valve Type II
XS Engineering Power Intercooler (GTR Core: 627mm x 272mm x 76mm)
APEX’i Dual Funnel Power Air Filter Kit
APEX’i Super Ground Stabilizer
Sun Automobile Hyper Ground System (S–Type)
Sun Automobile Hot Earth Muffler Ground
Optima Yellow Top Battery
MSD Ignition SCI Module
MSD Ignition Blaster SS Coil
MSD Ignition Pro Cap
NGK Power Cable
Denso Iridium Spark Plugs (IK24: 0.030”)
Walbro High Pressure Fuel Pump (255 LPH)
Edelbrock Pro–Flo EFI Fuel Rail
Vortech Fuel Management Unit (4:1)
Diamond–Star Motors OEM 4G63 Turbo Fuel Injectors (450cc)
Honda OEM OBD–I Resistor Assembly
Synapse Engineering Missing Link
Hondata Heatshield Intake Manifold Gasket (Ported Intake Manifold)
B&M Supercooler Racing Oil Cooler (Transmission: 280mm x 205mm x 40mm)
B&M Supercooler Racing Oil Cooler (Engine: 280mm x 280mm x 40mm)
Carbing Street Oil Catch Tank
Spoon Sports Magnetic Oil Drain Bolt
Spoon Sports Radiator Stay
Koyo Racing Radiator (345mm x 420mm x 53mm)
Cusco High Pressure Cap (18.4 PSI)
SPAL 13” Radiator Fan (Pull)
Samco Sport Coolant Silicone Hose Kit
Mugen Power Thermo Switch
Mugen Power Thermostat
automatic d16y8
358 hp
295 tq
11.6 @ 117.45 mph
tanakaracing
I sell t3/t4 hybrid turbo kits for b and d series, if you want i can send you some pictures to see email me at eclipsego7@hotmail.com the price is 1500 usd if you live in miami. if you don`t the shipping to your state will be added.
hondaSi_col
d16a9
dsm 450
stock internals
vitara pistons
garret t3/t4 TO4 super 60
external watesgate
Crome - 14psi @ 265Whp
all pipe 2.5''
intercooler XS
BOV Turbo XS RFL
and this is the Pic
Ellrot
D16 series Block
HKS Head Gasket
Standard internals
400cc injectors
competition Radiator
stand alone fuel management sytem
Re-mapped on a rolling road
7 psi Boost
200hp
I've only recently turbo'd my civic, so still I've discovered a couple of Niggles, I was running 180 hp at first because I was entered in the Modified gumball this year. I found everything runnig sweetly untill the last day when I realised the standard head unit couldn't hacket and I was over heating. So I changed that to the HKS head gasket and got myself a radiator about 4 times the thickness. This seems to do the trick.
But now I have just blown a hole in the manifold, which is caused by the heat and the hard suspension. so Reinforcements are a good idea.
rey_boricua
2000 EM1 B16A2T
JDM H22a
Wiseco 8.5:1 Pistons
Darton Sleeves
Crower I Forged Rods
Greddy Balancer Belt
Greddy Timing Belt
Crower Valve Springs & Retainers
Crower Turbo Cams
Port & Polish (Intake and Exhaust sides)
ARP Head Studs
Cometic Head Gasket
Golden Eagle Intake Manifold
MSD external coil
MSD cap
TURBO SETUP:
Quick4 Spoolin performance turbo manifold
3 inch down pipe
Spoolin performance Intercooler & Piping
38mm Tial Wastegate
GARRETT t3/60-1 trim turbo
COMPRESSOR SPECS:T04S housing
flow: 61 lbs/min 781cfm
.70 A/R housing
60 TRIM wheel
TURBINE SPECS:T3
.63 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
B&M pressure regulator
255lph walbro pump
1000cc precision injectors
Greddy RS BOV
NEPTUNE RTP
jdm98coupe
JDM H22A with LSD
D16Y8 stock on 6lbs
T25 turbo .48
2.5" intercooler piping
ebay front mount intercooler 28x2.5x7
dsm 450cc injectors
dsm 1st gen bov
po6 chipped ecu converted to vtec runnin crome
2.5" exhaust
custom downpipe
oem headgasket
3-angle valve job
street tuned for now will be dyno tuned in the near future and putting the boost up to 9lbs soon also.
h22_ek
1st gen crx
t3 turbo 8psi
custom oil box
safc 2
440cc injectors
all pipe is pvc lol
1.5 inch from turbo to fmic
2.0 from fmic to intake mani
custom 3" down pipe
msd btm
metal head gasket
arp head bolts
and many many more lol total spent <1500
1/4 times estimated in the low 13 high 12s wont no till next season
EG-Owns you
Twin Tech Owns Your s**t!
Home made turbo kits FTW not this was just a summer build to have some fun with because my fully built n/a b20 vtec dropped a valve. i hated boost from the beginning and now i hate it even more. just happy to have it out and ready for the Built B again woot.
setup
d16z6
dsm 450 injectors
missing link
hond data street tuned
manual boost controller
greedy down pipe
g15 turbo
random pipping had laying around
side mount inter cooler from a first gen
greedy type s BOV
act stage 1 clutch flywheel
8 -13 psi
all of this built for under $700
Road Pirate
Member
'00 civic coupe
D16Y8
HF manifold
AiResearch T2 T28
2.5" DP
2.5" custom charge piping
Blitz DD blow off valve
Whistler Bearing oil lines
31X12X3" Intercooler
Silicone Intakes couplers and T bolt clamps
Walbro HF fuel pump
DSM 450CC's
Tuned on Crome
PR8urVTEC
currently stock LS-T
swapping in about 2 weeks
built B20 block low 9.1 cr
Rare PR8 b20 head
GSR tranny
crower Stage 2 turbo cams
dual valve springs and retainers
GT2871r turbo
hondata s200r/c 750cc injectors
18psi
xxsenceo89x
aka superman
d16z6
vitara/eagle/arps
stock y8 head with cam gear.
t3 42/48
big greddy ic
ebay bov
tail wastegate
rc 750's
p06 vtec tuned on ectune
will update after dyno
Astheros
AMPhotography
d16z6
vitara/eagle/arps
t3 42/48
big greddy ic
ebay bov
tail wastegate
rc 750's
how much did the rods, pistons kit run you? i am boosting this month and i was considering just doing the vitara setup while i am at it.
djmobil2
2006 CIVIC SI
Lot of modifications done and a lot more to come!
to much for list but.....Precision 6061 Turbo, Tial 44mm WasteGate, Precision 680cc inyectors, Aereomotive fuel regulator, Walbro 255 fuel pump, 3in downpipe with Dynomax exhaust, front mount intercooler, AEM UEGO Wideband, Golden Eagle fuel rail with fuel return kit, Hondata Reflash, AJPerformance turbo manifold, HKS Blowoff Valve, Full Race Vaccum block, AEM Tru Boost controller, 18"in HFP (Honda Factory Performance) rims, Ingalls Stiffy Adjustable Engine Torque Damper, NGK BKR7E-11 plugs, and OEFog lights.
First Dyno run 302WHP @ 8PSI on 4th gear
EGHseries
have a question i need a pic of a h23 turboed just for some research i am doing but i cant find a good one anywhere
